export to acad 200
jimp178
58
I have just loaded SW2004.
Now when I try to save my drawing file as Acad2002 using the same Template that I used with SW2003.
It brings the Tittle block and Standard sheet in at a different scale as the drawing,showing it smaller and down at the left hand corner.
It is A standard sheet I manufactured my self with our company standards, it worked ok in SW2003 for the last year.
Any ideas would be very much appreciated.
Thanks in advance JimP
I tried ours several ways to try and duplicate your issue, but no luck. I tried all the values available from the Options button on the SaveAs DWG dialog box. I figured it had something to do with the Scale being on or off, or setting the Scale output to View or something.
I had a drawing with 3 views and all were set to a different scale, hoping the sheet would wig-out. So, unless I stumble on something, I can't get mine to fail...
Mr. Pickles
