Export Intralink database using Oracle exp/expdp utility
  • Thread starter Thread starter GiMario
  • Start date Start date
G
GiMario
Guest
Hello all.
I'm trying to export/import an Intralink db (from Oracle 10g to Oracle 9i). If I use the Intralink export/import batch files, it wont work, because of the different Oracle versions. The solution should be to export the source db using exp 9i utility, but i dont know how to do that on Intralink (i always used the ilink batch files).
Is it possible? How?
Thank You very much for any help.
