Thanks cowski, I did export .dat before posting but I can't open it with a mesh software like blender or meshlab, I suspect this option is strictly for engineering software like matlab etc.
I wanted to use this mesh for 3d printing because it's much cleaner than what the regular 'remesh' option gives you. Exporting as default .stl is the messiest so I don't even touch it. I had best results with 'remesh' but using variable triangle size. That was the cleanest geometry so far. The issue is when you print in high definition using a regular .stl export it creates bands on parts.
Thanks anyway though.
