export drawing sheets to PDF help
JAYDEE66
Aerospace
Jan 6, 2020
13
I have Found a great journal online that creates a PDF of all the drawing sheets in the current part file. What I would like to have is a journal that will pause and let me select which sheets I want in the PDF file. example. If there are 8 sheets and I only want sheet 2 and 4 to be in the PDF file I would like to be able to select only sheets 2 and 4. I have limited journal experience and could use the help. if anyone knows where there might be a journal like this online I would appreciate it if you could share it.
thank you
Try this:
Code:
Option Strict Off
Imports System
Imports System.IO
Imports System.Collections
Imports System.Collections.Generic
Imports System.Windows.Forms
Imports System.Windows.Forms.MessageBox
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim shts As New ArrayList()
Dim myForm1 As New Form1
Sub Main
Dim dwgs As Drawings.DrawingSheetCollection
dwgs = workPart.DrawingSheets
Dim sheet As Drawings.DrawingSheet
Dim i As Integer
Dim pdfFile As String
Dim currentPath As String
Dim currentFile As String
Dim exportFile As String
Dim partUnits As Integer
Dim strOutputFolder As String
Dim strRevision As String
Dim rspFileExists
Dim rspAdvancePrint
'determine if we are running under TC or native
Dim IsTcEng As Boolean = False
Dim UFSes As UFSession = UFSession.GetUFSession()
UFSes.UF.IsUgmanagerActive(IsTcEng)
partUnits = displayPart.PartUnits
'0 = inch
'1 = metric
If IsTcEng Then
   currentFile = workPart.GetStringAttribute("DB_PART_NO")
   strRevision = workPart.GetStringAttribute("DB_PART_REV")
Else 'running in native mode
   'currentFile = GetFilePath() & GetFileName() & ".prt"
   currentPath = GetFilePath()
   currentFile = GetFileName()
   Try
       strRevision = workPart.GetStringAttribute("REVISION")
       strRevision = Trim(strRevision)
   Catch ex As Exception
       strRevision = ""
   End Try
End If
exportFile = currentFile
strOutputFolder = OutputPath()
'if we don't have a valid directory (ie the user pressed 'cancel') exit the journal
If Not Directory.Exists(strOutputFolder) Then
   Exit Sub
End If
strOutputFolder = strOutputFolder & "\"
rspAdvancePrint = MessageBox.Show("Add advance print watermark?", "Add Watermark?", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
For Each sheet in dwgs
shts.Add(sheet.Name)
Next
shts.Sort()
if shts.count() > 1 then
	myform1.shts = shts
	myForm1.ShowDialog()
	If myForm1.Canceled Then
		'Exit sub
		Return
	End If
	shts = myform1.shts
end if
i = 0
Dim sht As String
For Each sht in shts
       If sheet.name = sht Then
           i = i + 1
           If rspAdvancePrint = vbyes Then
               pdfFile = strOutputFolder & exportFile & "_advance" & ".pdf"
           Else
               If strRevision <> "" Then
                   pdfFile = strOutputFolder & exportFile & "_" & strRevision & ".pdf"
               Else
                   pdfFile = strOutputFolder & exportFile & ".pdf"
               End If
           End If
           'the pdf export uses 'append file', if we are on sheet 1 make sure the user wants to overwrite
           'if the drawing is multisheet, don't ask on subsequent sheets
           If i = 1 Then
               If File.Exists(pdfFile) Then
                   rspFileExists = msgbox("The file: '" & pdfFile & "' already exists; overwrite?", vbyesno + vbquestion)
                   If rspFileExists = vbYes Then
                       Try
                           File.Delete(pdfFile)
                           msgbox(ex.message & vbcrlf & "Journal exiting", vbcritical + vbokonly, "Error")
                           Exit Sub
                       End Try
                   Else
                       'msgbox("journal exiting", vbokonly)
                       Exit Sub
                   End If
               End If
           End If
           'update any views that are out of date
           theSession.Parts.Work.DraftingViews.UpdateViews(Drawings.DraftingViewCollection.ViewUpdateOption.OutOfDate, sheet)
           Try
               ExportPDF(sheet, pdfFile, partUnits, rspAdvancePrint)
           Catch ex As exception
               msgbox("Error occurred in PDF export" & vbcrlf & ex.message & vbcrlf & "journal exiting", vbcritical + vbokonly, "Error")
               Exit Sub
           End Try
           Exit For
       End If
   Next
Next
   If i = 0 Then
       MessageBox.Show("This part has no drawing sheets to export", "PDF export failure", MessageBoxButtons.ok, MessageBoxIcon.Warning)
   Else
       MessageBox.Show("Exported: " & i & " sheet(s) to pdf file" & vbcrlf & pdfFile, "PDF export success", MessageBoxButtons.ok, MessageBoxIcon.Information)
   End If
End Sub
Function GetFileName()
   Dim strPath As String
   Dim strPart As String
   Dim pos As Integer
   'get the full file path
   strPath = displayPart.fullpath
   'get the part file name
   pos = InStrRev(strPath, "\")
   strPart = Mid(strPath, pos + 1)
   strPath = Left(strPath, pos)
   'strip off the ".prt" extension
   strPart = Left(strPart, Len(strPart) - 4)
   GetFileName = strPart
End Function
Function GetFilePath()
   Dim pos As Integer
   GetFilePath = strPath
End Function
Function OutputPath()
'Requires:
'    Imports System.IO
'    Imports System.Windows.Forms
'if the user presses OK on the dialog box, the chosen path is returned
'if the user presses cancel on the dialog box, 0 is returned
Dim strLastPath As String
Dim strOutputPath As String
'Key will show up in HKEY_CURRENT_USER\Software\VB and VBA Program Settings
Try
  'Get the last path used from the registry
  strLastPath = GetSetting("NX journal", "Export pdf", "ExportPath")
  'msgbox("Last Path: " & strLastPath)
  Catch e As ArgumentException
  Catch e As Exception
  msgbox (e.GetType.ToString)
  Finally
End Try
Dim FolderBrowserDialog1 As New FolderBrowserDialog
' Then use the following code to create the Dialog window
' Change the .SelectedPath property to the default location
With FolderBrowserDialog1
    ' Desktop is the root folder in the dialog.
    .RootFolder = Environment.SpecialFolder.Desktop
    ' Select the D:\home directory on entry.
   If Directory.Exists(strLastPath) Then
       .SelectedPath = strLastPath
   Else
       .SelectedPath = "D:\home"
   End If
    ' Prompt the user with a custom message.
    .Description = "Select the directory to export .pdf file"
    If .ShowDialog = DialogResult.OK Then
       ' Display the selected folder if the user clicked on the OK button.
       OutputPath = .SelectedPath
       ' save the output folder path in the registry for use on next run
       SaveSetting("NX journal", "Export pdf", "ExportPath", .SelectedPath)
   Else
       'user pressed 'cancel', exit the subroutine
       OutputPath = 0
       'exit sub
    End If
End With
End Function
Sub ExportPDF(dwg As Drawings.DrawingSheet, outputFile As String, units As Integer, advancePrint As Integer)
   Dim printPDFBuilder1 As PrintPDFBuilder
   printPDFBuilder1 = workPart.PlotManager.CreatePrintPdfbuilder()
   printPDFBuilder1.Scale = 1.0
   printPDFBuilder1.Action = PrintPDFBuilder.ActionOption.Native
   printPDFBuilder1.Colors = PrintPDFBuilder.Color.BlackOnWhite
   printPDFBuilder1.Size = PrintPDFBuilder.SizeOption.ScaleFactor
   If units = 0 Then
       printPDFBuilder1.Units = PrintPDFBuilder.UnitsOption.English
   Else
       printPDFBuilder1.Units = PrintPDFBuilder.UnitsOption.Metric
   End If
   printPDFBuilder1.XDimension = dwg.height
   printPDFBuilder1.YDimension = dwg.length
   printPDFBuilder1.OutputText = PrintPDFBuilder.OutputTextOption.Polylines
   printPDFBuilder1.RasterImages = True
   printPDFBuilder1.ImageResolution = PrintPDFBuilder.ImageResolutionOption.Medium
   printPDFBuilder1.Append = True
   If advancePrint = vbyes Then
       printPDFBuilder1.AddWatermark = True
       printPDFBuilder1.Watermark = "ADVANCE PRINT NOT TO BE USED FOR PRODUCTION " & Today
   Else
       printPDFBuilder1.AddWatermark = False
       printPDFBuilder1.Watermark = ""
   End If
   Dim sheets1(0) As NXObject
   Dim drawingSheet1 As Drawings.DrawingSheet = CType(dwg, Drawings.DrawingSheet)
   sheets1(0) = drawingSheet1
   printPDFBuilder1.SourceBuilder.SetSheets(sheets1)
   printPDFBuilder1.Filename = outputFile
   Dim nXObject1 As NXObject
   nXObject1 = printPDFBuilder1.Commit()
   printPDFBuilder1.Destroy()
End Sub
End Module
'* FORM1
Public Class Form1
	Public shts As New ArrayList()
	Public shts2 As New ArrayList()
Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
	for each shtname as string in shts
		ListBox1.Items.Add(shtname)
	next
End Sub
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
	shts = shts2
	Me.Close()
End Sub
Private Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.Click
	_canceled = True
	Me.Close()
End Sub
Private Sub ListBox1_SelectedIndexChanged(sender As Object, e As EventArgs) Handles ListBox1.SelectedIndexChanged
	shts2.Clear()
    For Each Item As Object In ListBox1.SelectedItems
		shts2.add(Item)
    Next
End Sub
Private _canceled As Boolean = False
Public ReadOnly Property Canceled() As Boolean
	Get
		Return _canceled
	End Get
End Property
End Class
<Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()> _
Partial Class Form1
Inherits System.Windows.Forms.Form
<System.Diagnostics.DebuggerNonUserCode()> _
Protected Overrides Sub Dispose(ByVal disposing As Boolean)
	Try
		If disposing AndAlso components IsNot Nothing Then
			components.Dispose()
		End If
	Finally
		MyBase.Dispose(disposing)
	End Try
End Sub
Private components As System.ComponentModel.IContainer
<System.Diagnostics.DebuggerStepThrough()> _
Private Sub InitializeComponent()
	Me.Button1 = New System.Windows.Forms.Button()
	Me.Button2 = New System.Windows.Forms.Button()
	Me.ListBox1 = New System.Windows.Forms.ListBox()
	Me.Label1 = New System.Windows.Forms.Label()
	Me.SuspendLayout()
	'Button1
	Me.Button1.Location = New System.Drawing.Point(36, 205)
	Me.Button1.Name = "Button1"
	Me.Button1.Size = New System.Drawing.Size(75, 23)
	Me.Button1.TabIndex = 0
	Me.Button1.Text = "Ok"
	Me.Button1.UseVisualStyleBackColor = True
	'Button2
	Me.Button2.Location = New System.Drawing.Point(149, 205)
	Me.Button2.Name = "Button2"
	Me.Button2.Size = New System.Drawing.Size(75, 23)
	Me.Button2.TabIndex = 1
	Me.Button2.Text = "Cancel"
	Me.Button2.UseVisualStyleBackColor = True
	'ListBox1
	Me.ListBox1.FormattingEnabled = True
	'Me.ListBox1.Items.AddRange(New Object() {"A", "B", "V", "X", "D"})
	Me.ListBox1.Location = New System.Drawing.Point(12, 30)
	Me.ListBox1.Name = "ListBox1"
	'Me.ListBox1.SelectionMode = System.Windows.Forms.SelectionMode.MultiSimple
	Me.ListBox1.SelectionMode = System.Windows.Forms.SelectionMode.MultiExtended
	Me.ListBox1.Size = New System.Drawing.Size(240, 160)
	Me.ListBox1.TabIndex = 2
	'Label1
	Me.Label1.AutoSize = True
	Me.Label1.Location = New System.Drawing.Point(12, 10)
	Me.Label1.Name = "Label1"
	Me.Label1.Size = New System.Drawing.Size(72, 13)
	Me.Label1.TabIndex = 4
	Me.Label1.Text = "Choose Sheets to exsport: "
	'Form1
	Me.AutoScaleDimensions = New System.Drawing.SizeF(6.0!, 13.0!)
	Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font
	Me.ClientSize = New System.Drawing.Size(280, 280)
	Me.Controls.Add(Me.Label1)
	Me.Controls.Add(Me.ListBox1)
	Me.Controls.Add(Me.Button2)
	Me.Controls.Add(Me.Button1)
	Me.AcceptButton = Button1
	Me.CancelButton = Button2
	Me.FormBorderStyle = System.Windows.Forms.FormBorderStyle.Sizable
	Me.MaximumSize = New System.Drawing.Size(280, 280)
	Me.MinimumSize = New System.Drawing.Size(280, 280)
	Me.MaximizeBox = False
	Me.MinimizeBox = False
	Me.Name = "Form1"
	Me.StartPosition = System.Windows.Forms.FormStartPosition.CenterScreen
	Me.Text = "Sheets to exsport:"
	Me.ResumeLayout(False)
	Me.PerformLayout()
End Sub
	Friend WithEvents Button1 As Button
	Friend WithEvents Button2 As Button
	Friend WithEvents ListBox1 As ListBox
	Friend WithEvents Label1 As System.Windows.Forms.Label
End Class
With best regards
Michael
This is the file I found.
The journal you sent works great thank you very much.
Do you know if the journal you sent can be changed to automatically select the folder that the part file is in and the ability to change the PDF name?
'Programmed on 02-05-2010 by cowski
'This journal was created to automate exporting drawings to .pdf format
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Module NXJournal
Sub Main
Dim dwgs as Drawings.DrawingSheetCollection
Dim i as integer
Dim pdfFile as string
Dim currentPath as string
Dim currentFile as string
Dim partUnits as integer
'0 = inch
'1 = metric
i = 0
'msgbox (sheet.name)
i = i + 1
pdfFile = GetFilePath() & GetFileName() & ".pdf"
try
ExportPDF(sheet, pdfFile, partUnits)
catch ex as exception
msgbox("Error occurred in PDF export" & vbcrlf & ex.message & vbcrlf & "journal exiting", vbcritical + vbokonly)
exit sub
end try
Next
if i = 0 then
msgbox("This part has no drawing sheets to export")
else
msgbox("Exported: " & i & " sheet(s) to pdf file" & vbcrlf & pdfFile, vbokonly + vbinformation)
end if
End Sub
Dim strPath as String
Dim strPart as String
Dim pos as Integer
End Function
Dim pos as Integer
End Function
Sub ExportPDF(dwg as Drawings.DrawingSheet, outputFile as string, units as integer)
if units = 0 then
else
end if
End Sub
End Module
Change:
Code:
to
Code:
strOutputFolder = CurrentPath
What do You mean by "ability to change PDF name"?
With best regards
Michael
I changed the journal as follows
1. removed the option for the watermark.
2. included the ability to name the PDF a name of your choice. The file is put in the folder that the .prt file is located.
I am new to the eng tips, can you tell me how you add the code box?
Code:
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
Sub Main
Dim i As Integer
Dim rspFileExists
'0 = inch
'1 = metric
If IsTcEng Then
   Try
       strRevision = ""
   End Try
End If
   Exit Sub
End If
Dim userSelectedFileName = exportFile & ".pdf"
userSelectedFileName = InputBox("Enter File Name", "NAME OF FILE", userSelectedFileName)
If String.ReferenceEquals(userSelectedFileName, String.Empty) Then
    Exit Sub
End If
pdfFile = strOutputFolder & userSelectedFileName
Next
shts.Sort()
	myform1.shts = shts
		'Exit sub
		Return
	End If
	shts = myform1.shts
end if
i = 0
Dim sht As String
           i = i + 1
           If i = 1 Then
                       Try
                           Exit Sub
                       End Try
                   Else
                       Exit Sub
                   End If
               End If
           End If
           Try
               Exit Sub
           End Try
           Exit For
       End If
   Next
Next
   If i = 0 Then
   Else
   End If
End Sub
   Dim pos As Integer
End Function
   Dim pos As Integer
End Function
'Requires:
'    Imports System.IO
Try
  Finally
End Try
 OutputPath = GetFilePath()
End Function
Sub ExportPDF(dwg As Drawings.DrawingSheet, outputFile As String, units As Integer)
   If units = 0 Then
   Else
   End If
End Sub
End Module
'* FORM1
Public Class Form1
	next
End Sub
	shts = shts2
	Me.Close()
End Sub
	_canceled = True
	Me.Close()
End Sub
	shts2.Clear()
		shts2.add(Item)
    Next
End Sub
	Get
		Return _canceled
	End Get
End Property
End Class
Partial Class Form1
	Try
		End If
	Finally
	End Try
End Sub
	Me.SuspendLayout()
	'Button1
	'Button2
	'ListBox1
	'Label1
	Me.Label1.Text = "Choose Sheets to export: "
	'Form1
	Me.Name = "Form1"
	Me.Text = "Sheets to export:"
	Me.PerformLayout()
End Sub
End Class
Code box? Do You mean text box? If so, the best way is design new form by "visual studio", and after that paste your code to journal below like in my example.
With best regards
Michael
To format your code on eng-tips, use the [ignore]
Code:
[/ignore] tags around your code. The question mark icon next to the "preview" button will give you all the available tags (you may need to scroll down to see the help box).
www.nxjournaling.com
Thank you cowski. That works great, BTW you probably recognize some or most of the code in the journal. thanks again
