Export Assemly navigator to Excel and save file Batch Journel
RyanVLee
Industrial
Apr 28, 2011
67
thread561-311938
I am trying to batch create export of assembly navigator to a file and run thru a folder of parts. I used the journal attached below to batch create 250,000 pdfs. I am hoping that some one who knows vb and journal creation can help out
Ryan Lee
Mechanical Project Engineer
NX 6.0.5.3
NX 9.0.1.3(Testing)
If you can think it it can be modeled
 http://files.engineering.com/getfile.aspx?folder=8c344ae5-164d-48e1-883e-b173841c3189&file=cyclePartFiles_pdf.vb
The NX API does not give you direct access to the navigators (at least not as of NX 9); what this means is that you cannot query the assembly navigator and export the information to a file. However, most (all?) of the information displayed in the assembly navigator can be accessed through the API. You'd need to decide what information that you need, write code to gather the info, then write it to your file.
www.nxjournaling.com
