Cal/OSHA requires an Injury and Illness Prevention Program (IIPP) of every employer. If you ever have an accident investigated by Cal/OSHA, you better best be able to come up with signed & dated safety training for each employee. I also kept signed & dated attendence sheets of safety meetings, but don't remember if mandatory or a CYA precaution.
A sample
IIPP for High Hazard Employers is at
Page 12 has a checklist for WELDING, CUTTING & BRAZING.
This specific hazard isn't listed, but would fall into several general categories for "appropriate operating instructions" and "only approved apparatus."
More Cal/OSHA publications are available at
Cal/OSHA regulations are in Title 8 of the CCR (California Code of Regulations):
Welding & Flammable vapors are found in
Division 1. Department of Industrial Relations
Chapter 4. Division of Industrial Safety
Subchapter 4. Construction Safety Orders
"Article 32. Oxygen, Acetylene, and Fuel Gas
§1740. Storage and Use of Cylinders.
(e) Cylinders must not be placed where they might form a part of any electric circuit." [doesn't mention a torch]
"Article 4. Dusts, Fumes, Mists, Vapors, and Gases
§1534. Flammable Vapors.
(a) Flammable vapors shall be controlled so as to avoid hazard to workers.
(b) No source of ignition such as smoking, gas pilot lights, or operating electrical equipment, other than explosion-proof or equivalent, shall be allowed in a room or building when hazardous concentrations of flammable vapors are present."
Lighting acetylene with an arc might be considered an (a) hazard or, if the arc melts a hole in the torch, hazardous concentrations of flammable vapors would be present pretty quick.
Requirements of appropriate eye protection as mentioned by
swall can also be found.
