Explosion Protection in Small Ribbon Blender?
wk390107
NL
I am currently evaluating adding a small ribbon blender to be used in our compounding area to mix additives. This is small semi-portable ribbon blender that is only 15 cubic feet in volume. I am trying to determine if it needs to be under a nitrogen purge to avoid a possible dust explosion since it is so small.
Any advice that could point me in the right direction to determining this would be greatly appreciated. Thanks!
I know per NFPA 654 7.2.3.3 that fixed bulk containers do not have to have explosion protection if they are <8cf, and that NFPA 654 7.13.1.1.2 says air-material separators that have a volume of less than 8cf do not need to have explosion proofing either.
I am guessing that a blender would likely go by the same 8cf maximum, but I am unsure. It seems rather excessive to have to inert such a small volume.
What would create the explosion in your compounding blender?
Inerting is cheap. Would you take the chance? Secondly, you didn't tell us the material MIE, MEC or Kst.
NFPA 69 covers oxygen consentration for explosion protection.
