Exploded views trouble
Kathie
22
I am working on an exploded view and everything was fine.
Next time I ran the animated explode, all the components were just "blocks" with no detail. I don't think I changed a setting - any suggestions?
Kathy,
Check your large assembly mode settings under options > system. Also, check out this link thread559-117984
One other item is your video card, & driver on the certified SWx list. It would also help other in the future if you could put your system description in you signature..
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
If you are using SW 2005, I think the option you want to change is Tools > options > System Options > Performance > Level of Detail.
Do they remain as blocks after the motion has completed? If so, I'd suspect your graphics card. If not, I'd suspect your setting above.
If you don't already know about the graphics cards, check the SolidWorks web site for compatible cards and whether they passed, passed with coments or cautionary notes, or failed. Your exploded view may be over-running your card's capacity to display the objects in your screen correctly.
Jeff Mowry
Reality is no respecter of good intentions.
