I believe I understand the concept of saturation - that all the magnetic domains available in the core have been aligned, so flux density cannot increase, and therefore secondary emf and current collapses. However, I am trying to figure out why current increases so dramatically on a CT excitation curve past saturation.
Is it accurate to say that, at the point of saturation, the core can no longer do its job of transmitting (verb?) flux, and therefore:
1) the load-side winding is no longer coupled, leading the load seen by the supply-side winding to be simply the supply-side winding inductance, and
2) the supply-side winding essentially becomes an air-core inductor (with μ_air << μ_iron and therefore L_aircore << L_ironcore) and therefore have a very low Z_L
So the effect is a double whammy. Is that view correct?
