marajendra
Link
My take is this.
The magnets are conductive.
And any given instant, the magnet completes an electric circuit composed of the battery and a section of the coil (toroid) thereby forming a solenoid around the battery-magnet assembly. The assembly is in the center of the solenoid. We know that the magnetic field of a solenoid is almost constant inside the solenoid (except for fringing effect near the ends)decreases when we move away from the ends. So, this create a non-uniform magnetic field around the assembly.
The north and south poles of the magnet is oriented so that the magnetic field of solenoid and of the magnets are oppositely oriented, and the solenoid field will tend to push the magnets away from the center and towards the weaker field. And hence the assembly moves away, a bit. And in the next instant, it completes another section of the coil, forming another solenoid and the process repeats.
If the assembly is flipped over, it will still work, because the battery polarity will also be reversed and the solenoid will produce magnetic field in the other direction. However, if only the magnets are flipped over the battery, then I think the assembly will tend to be stuck at the center, because the magnetic filed of the solenoid and that of the magnet will tend to pull each other. Also, instead of flipping the magnet, if a different toroid, where the wire is wound the other way is used, it will fail.
Also, if the battery was dead, and if someone was to power the toroid from external supply, it won't work, because, then the magnetic field of the toroid would be uniform and hence no force would apply to the magnet assembly.
Am I right?
My take is this.
Am I right?
