Does anyone have experience with O-Matix?
I used to do a lot of programming with visual Basic but for the last few years have been using Mathematica CalcCenter. I actually do like CalcCenter but for larger programs it seems to take longer than it would have with Basic, in particular the longer ones. Some of my programs get into quite a bit file access for the purpose of evaluating output of structural analysis programs. Before I go back to Visual Basic I started to look for something different and came up with O-Matrix. It seems to have a Basic look to it and I think I might like it.
I like CalcCenter for its easy handling of mathematics and the fact that a single file contains both the equations for the calculations and the results. Basic on the other hand requires you to work at getting the output formatted to look good. You will have an output file or print out, and a program file. If matrix math is needed you write the routines yourself. CalcCenter is capable of extremely sophisticated mathematics.
Or maybe there's something else that would fit the bill.
Any comments would be appreciated.
Thanks,
-Mike
Thanks,
-Mike
