Engineer6512
I am working on an industrial fan application. These are 50 hp, 1800 rpm, 10,000 cfm fans operating at a pressure of 57" WG.
The fans are mounted using vibration isolators on structural steel. There are flanged connections to both the suction and discharge ductwork. Maximum vibration is 68 mils.
In the fan manufacturers documentation they are saying that expansion joints are required on fan inlet and outlet. The problem is that I have extremely limited space as it is. I am planning to simply use approx. 1/2" rubber gasket between the flanges on both inlet and outlet.
Just wondering what some of your thoughts are on going this route instead of one of the commerically availble expansion joints.
Thanks.
Thanks.
