ash060
- Nov 16, 2006
- 473
I am working on a job that has an existing 8" masonry wall sitting on a monolithic 16"x10" footing. The wall is about 25' tall braced at 24'. The wall is currently non-load bearing.
The owner wants to add 3 stories to the building and continue up from the existing masonry with new masonry. The wall will be load bearing in the new levels. I have checked the wall, and the existing masonry wall looks like it can take the additional load, but the footing does not have a chance of working.
the contractor wants to keep the wall, but remove the current slab-on-grade and replace with a mat foundation between the exisiting monolithic foundation for all the new columns we are adding for the new structure.
How can I modify the wall foundation to make it work?
The allowable bearing is 2500psf
The new wall load is about 6 k/ft
