liquiddecay
Nuclear
my facility has two 15,000 gallon #2 fuel oil (FO) tanks. On one of the tanks the insulation has deteriorated and begun to fall away. It is the foam-type, wrapped by aluminum and bound by strapping.
My question is: does any code stipulate that the insulation must be repaired?
The FO is #2 grade, utilized in boilers in a CHP for space heating in campus buildings. It is not heated nor do the pumps run when the boilers are secured. Understandably, as the weather becomes colder, it will adversely affect the viscosity of the FO.
Again, my question is from a legal/code compliance concern rather than an operational standpoint.
Thanks in advance as any input would be appreciated.
