SME456
Agricultural
- Aug 22, 2006
- 2
I've read several of you posts regarding this issue and found them very helpful. I'm current working on some noise issues for off-highway equipment and am working with a supplier to design a new muffler. With the new muffler I'm forced to design a new 5in. dia. tube to run between the turbo and muffler. Because of component locations the tube requires a 90 deg bend located about 15in from the engine. As long as I'm in the design phase I'd like to investigate using a laminated pipe for that section. Do any of you know of a supplier I could work with on this?
