purplemonkey
Automotive
- May 22, 2007
- 31
Hello all,
I am not very familiar with CFD however I have been using CFDesign in order to verify some design data on exhaust flow characteristics and pressures.
The system being modelled is from a single turbo back through to a splitter box which splits the flow into two pipes before continuing through the system through some complicated piping and routed to the atmosphere.
The engine manufacturer recommends no more than 3 in-Hg of back pressure right after the turbo outlet, however the analysis I am running is showing upwards of 5 in-Hg. The complexity of the system is very great and I would like to alter my design and recheck computationally without having to wait another 5 days for a solution to be formed.
My question is:
In order to simplify the complexity of the system and reduce the number of cells, would it be appropriate to assume that the exhaust is routed to atmosphere at the outlets of the splitter box connection (since this is the device I am most concerned about)?
Your input/advice is greatly appreciated!
My question is:
