Execute a Unix command from VB
mjs84
Aerospace
Hello all,
I need to execute a Unix script from VB. Manually, I would open a shell using the dos 'cmd' command, and telnet to my unix site, then run the unix command. The problem with doing this programmatically is unlike it's ftp cousin, which has a -s parameter that allows you to use a text file containing all ftp commands, telnet does not offer this parameter.
Question 1. Can I use Telnet to do this, if so, how?
Question 2. Is there a better way to do this from a Win2000 machine?
Thanks in advance,
mjs84
I have a similar problem, i need to change the permisions of some files shared in a unix computer so i can read them. The files are generated by the ERP Baan and stored in a shared folder in a unix computer in the network. The files are generated with Read and Write permisions, but i can't open those files from windows. i have a user with all the permisions in the shared folder, but in windows, if i don't have the execute permision, i cannot open a file, so is there a way to execute a unix command from visual basic? or is there another way to change the permisions over a folder in a unix machine from visual basic?
thanks in advance
