CrazyHorse81
- Jun 18, 2004
- 73
Existing duplex, pitless water booster station serves 52 homes. Incoming transmission pipe is 6" PVC and serves about 3 homes along it. Piping thru pump house is 3-inch. Distribution piping consists of 6" PVC loops water mains that fills a stand pipe with dimensions of 14' and 110' tall. See HGL for reference and sketch for configuration.
The original pumps (now sitting on the pump house floor) are Webtrol WS09050 and should operate at about 142' TDH and 87 gpm based my calculations - also attached. These pumps have been barely producing 25 gpm and have burned through more than a few motors over the course of a year. In fact, the operator only filled the tank to ELEV.=1410 to get them to produce flow - again noted as F. on HGL.
The operator replaced them with Webtrol WT4050 submersibles. And based on fill times of the tank they averaged a flow rate of 45-50 gpm. That corresponds to a TDH of 275-300' about double of what I expect!
We stuck a pressure recorder upstream of the BPS and it steadily recorded upstream pressure of 60-65 psi (as expected). We also verified that all downstream valves were OPEN. I am missing something? I would size the pump of a flow rate of 45 gpm at 150' and have a nice day but something is awry.
Can someone chime in please?
