Excel Design Tables
  • Thread starter Thread starter Mutt_Marphy
  • Start date Start date
M
Mutt_Marphy
Guest
I am wondering with design tables, it is capable to extend a stock drawing through excel, much like a window from 900mm x 900mm to 985mm x 964mm, say for bespoke orders.
But it is capable to alter the pitch of say a new bespoke order ? From say a 25 degrees to 43 degrees.
Will this alter some components about which the pitch is changed, distorting them or will the software update the drawing to avoid these potential problems.
Thanks in advance
You can absolutely change an angle using a design table. If the model is properly built using parameters, the rest of the part of assembly should change accordingly.
Can you show me an example of the model that you are developing?
