Excavation by grab
Zambo
SG
I have seen clamshell grabs used for dredging (silt or sand) and for rock (say 3-10 tonne blasted rock) but what about excavation. Is it possible to use a wire operated clamshell to excavate a stiff clay? Or is it necessary to excavate with hydraulic equipment and use the mechanical grab just for soil movement.
If the clay is very stiff or dry, the clamshell won't get a good bite into the material. And this will make the excavating slower.
Richard A. Cornelius, P.E.
He is right.
However, if equipped with teeth, these buckets can do some digging in hard ground, but have little down pressure to help.
They seem to be most common handling aggregates and other loose materials in stock piles where a long reach is needed.
I've seen them regularly in use to clean out excavations in confined areas where other equipment just can't reach.
Good operator can drop clam from a height required to penetrate clay or other "hard" digging.
They are also used in well foundations (caissons) for bridge piers in order to dig out the material for sinking the well foundation.
I have seen many contractors go out of their way and spend lots of money trying to use a backhoe where a clam bucket should have been used. Most contractors don't even know what a clam bucket is. Most equipment operators haven't ever done any clamming. Those operators who have done clamming seem to be retired or dead. Clamming is slow but sometimes the amount of material to be excavated is not very great and the clam may did it just as fast or faster than a backhoe.
Sorry, I meant to type "dig it just as fast..."
