Event-Triggered Control
Annewillem
Industrial
NL
In order to simulate a tracking problem with event-triggered control I think I need to use a Triggered Subsystem. Actually, the problem is that the trigger for the Subsystem depends on the output of the Triggered Subsystem. If I want to simulate the model it gives a loop error.
It is not possible for me to use the Latch option, otherwise the model isn't appropriate anymore.
I tried some things with the option 'state output' of the integrator block to avoid loop errors, but then there is the problem that everytime the trigger occurs the sample of the state has to be kept constant until the next trigger occurs.
Are there any alternatives to deal with this situation?
Loop errors are usually corrected by putting a unit delay in the feedback loop.
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
