PurplePenguin
Computer
My question goes towards making a A/C unit pump out more or colder air on a hot day..
Could you direct a Evaporative Coolers output to a A/C units condenser unit to make the A/C produce colder air?
Again..
I have a few Semi-Truck trailers.. They have 3 3-ton A/C units with the Condenser mounted below the trailer. There is a "skirt" that goes around the trailer to make it look more.. finished instead of like a trailer.
The problem is under that "skirt" it gets quite warm as you could imagine from having 3 3-ton units operating full blast for a few hours on a 100+ degree day.
My question is would putting a Evaporative Cooler under there produce colder air for the condensers to use so that they in turn produce colder air..
Or would the Humidity factor into that and they would end up canceling each other out?
-Eric Peters
Again..
-Eric Peters
