Sorry, Cannot help, since I believe there is no such (conversion) document.
All standards are practically complementing each other. Some are more conservative compared to the others, and end-user’s principal to address whether the gap is marginal or not. In the end, what is more available in the market, are the ones that we are going for (in the case ASME/API/etc.)
For any valves within the fence of end user, in Netherlands, are more and more heading towards this direction. I work in refinery which used to have DIN, JIS, BS, ASME, Stoomwezen (old Dutch standard), etc. now we are synchronizing towards ASME and IOGP.
For pipeline and valves which are outside the fence (public domain) then usually it is governed by local rules. In NL and BE, we use NEN. But this also in my opinion has marginal deviation with regards to ISO.
3-5 years ago, or more, some may argue that one standard is better then other (comparable) standard. This practice has hurt End-User commercially for decades, hence IOGP was initiated.
My advice is to answer the question first: which industry (Oil/gas, pharma, dairy, etc.)? which country (UK, Europe mainland, Scandinavian)? Which domain (inside end user territory or public domain)?
Suggest buying the standards that you’re looking for, there are reasons why it is written in multiple pages. And why last page is always written as ‘Bibliography’ and not ‘Supplementary’.
Cherry picking one paragraph from one standard and use another para from different standard will eventually create confusion.
Bibliography of ISO 17292 below. not even mention any BS or EN standard:
ISO 4200, Plain end steel tubes, welded and seamless ʊ General tables of dimensions and masses per unit length
ISO 5211, Industrial valves ʊ Part-turn actuator attachments
ISO 7121, Metal ball valves for general-purpose industrial applications
ISO 10434, Bolted bonnet steel gate valves for the petroleum, petrochemical and allied industries
ISO 14313, Petroleum and natural gas industries ʊ Pipeline transportation systems — Pipeline valves
ISO 15761, Steel gate, globe and check valves for sizes DN 100 and smaller, for the petroleum and natural gas industries
API Standard 608, Metal ball valves ʊ Flanged, threaded and welding end
ASME B16.11, Forged fittings, socket-welding and threaded
ASME B16.25, Buttwelding ends
ASME B36.10, Welded and seamless wrought steel pipe
goodluck
regards,
D
