Iam modelling a villa in Etabs.I hav two Slab panels of size 6mx3m.thickness 150mm,side by side but at different level. one slab panel is at 4m above ground level n other panel is at 5m above ground level.i want to use only one beam to take the loads from these two slabs instead of two beams for two slabs at different levels.i want to model the beam in such a way taht it should be connected to both slabs n take the loads.can this be possible in etabs. please help
[/color]
[/color]
