Hi everyone!
I have slight problem with etabs column design result. When I designed my columns using the "to be designed" option, etabs gives an area of steel of around 3,400mm^2 on a 250x500mm column, but when I use the "to be checked" option and I input 10-16mm rebars equivalenting to around 2011mm2 of steel area, the column still passes the design.
How is that possible? The "to be designed" requires 3400mm2 of steel area but the "to be checked" with 2011mm2 of steel area still passes.
Is the "to be checked" method reliable?
Thank you in advance for your replies.
