JoshPlumSE
- Aug 15, 2008
- 10,511
I'm a engineer who works for a structural engineering sofware company.
There's a question that comes up from time to time that I don't have a good response for. Within the context of a linear elastic analysis program, we as structural (not geotechnical engineers) will use Modulus of Subgrade Reaction from our Geotech report as the basis for establishing vertical springs to resprsent the soil. I know that soil is not a linear elastic material. But, that's generally what is done.
The only problem is that we don't have any similar concept for lateral resistance of the foundation. I'm curious if anyone in this forum has any suggestions for what to use. Or, any references that might have suggestions.
My initial thoughts are the following, but I could be way off:
1) If I've got lateral friction resistance at the soil / foundation interface, I might use some percentage of the modulus of subgrade reaction. Something like 0.1 * the vertical soil spring used at this location.
2) For passive pressure resistance, I can make hand calculations to estimate the passive force resistance along the height of a retaining wall. But, to establish a spring constant I would need to estimate a expected deflection which would coincide with that passive pressure.
