Hello!
I am trying to make a fast acting check valve for use in the PCV system in a car with a turbo. Normally only half of the crankcase breather vents are open to the air under power, as the PCV closes in absence of vacuum. This works fine for a stock car, but I have increased blowby with the added output.
Instead of removing the PCV system and venting both halves of the valve cover, I would like to install a oil catch can with a check valve that opens with even a tiny bit of differential pressure while maintaining the PCV valve. I am thinking that in most cases the catch can will be under vacuum holding my catch can check valve closed and the system will work like normal, but in turbo boost the PCV will close, the catch can will pressurize a little and pop the check valve open so I have ventilation out both factory ports in my valve cover.
I think a check valve could be made using a 3/8NPT Male to 1/2NPT Female adapter, a 1/2NPT sintered vent, a 1/2" rubber ball, and a 1.6lb/in conical spring. Mcmaster has all this, for around what a commercial valve costs. I would mount all this vertical in the catch can, so gravity is helping seat the valve.
If Mcmaster solid models are halfway accurate, I expect 0.206in^2 of check ball exposed to pressure, or the acting piston area I guess.
And here's where I hit a wall! If we assume the valve "cracks" open at a incredibly small value, like a tenth of an inch, then the valve has to open with nearly no pressure differential? Otherwise I would think the math is simple, 1.61lb/in / 0.206in2 = 7.8PSI? That doesn't make sense, plus the valve can't even open an inch...
And so, I ask for any advise you are willing to give. Will this work like I expect it to? Do you think using rubber under ~1/2lb of spring preload against a seat like this is a good idea? I was planning on adding a small 90 degree chamfer to make an actual seat.
Thank you in advance!
