I have a faulty pressure regulator that was not designed for the service it is in and I must replace it. I was requested to find a proper control valve, rather than a regulator.
The regulator was to maintain pressure on a DA. The DA is fed by a condensate drum, going from 20 psig to 5 psig. The DA also has makeup water from an RO system.
How do I estimate the flow needed to maintain pressure on the tank so I can size a replacement pressure control valve?
Thank you for your help!
Onwards,
Matt
Onwards,
Matt
