I have a problem with this ESP. It is the external static pressure, external to what? If the mfr of the furnace wants you to exclude the pressure drop across the airhandler, and I picture a simplified flow system that has a series of algebraic static drops:
1) across the blower,a-b (actually a rise)
2) across the heating element, b-c
3) across the cooling coil, if any, c-d
4) from cooling coil exit thru supply ductwork to heating space,d-e
4) from heating space thru intake ducting to filter placed just before blower intake plenum, e-f
5) across the filter (assume filter before blower intake plenum) , f-a
Now, if you ignore the heating element and the filter drops is ESP the difference, c-a? If the filter is excluded then is it c-f? Or what do you think? I,m confused. And why do you think the mfr specs the esp vs max cfm?
