I have an issue that is eluding me regarding ESD grounding of carts. We have metal carts in our facility that we use for material movement between work stations (and some workers use for storage). In our previous building we had a regular linoleum tile floor which had ESD wax applied once a quarter. Because the wheels of the metal carts are not ESD grounded I used a drag chain attached to the bottom of every cart which has worked well for years. Testing with our ESD tester by putting one 5 lb electrode on the shelf of the cart and one on the floor. The carts measured in the dissipative range. Fast forward to the present. We bought a new building and spent a ton of money putting in static dissipative flooring in the production area. We grounded all our workstation ESD mats and everything passes when measured from the mat to the floor. However, I cannot get my carts to pass. I verify the top shelf is electrically connected to the bottom shelf and both are connected to the drag chain but I get an insulative reading on my meter when testing from the cart to the floor.
Additionally, using my static meter I see no indication of a static charge built up on the carts. Why am I not getting any continuity to the floor through the drag chain (I have even tried a much larger and heavier chain than the jack chain used in the old building)? Am I wasting my time trying to ground a metal cart that doesn't show any static charge? Curiously, I use my static meter on a PET disposable water bottle which are strictly banned from the production floor and see no static charge but the company provided and sanctioned covered mugs generate a ton of static. I talked with the flooring manufacturer and didn't get anywhere.
Any insight would be appreciated.
