Error Too many attempts for Increment
shahir
AT
hi
Error: Too many attempts for Increment
wat does this error really means?
the error message is exactly like this¨Too many attempts made for this increment¨
Means that the solver cannot obtain a converged solution with the default number of attempts. I think you can change the default - it'll be in the docs somewhere.
I must admit, I very rarely change the default. There's usually something fundamentally wrong with the model or the analysis has reached an instability (like a buckling load) for this to happen.
Martin
thx martin
i ll try to find
Too man increments can also occur in contact problems. if you have initial penetration of contact surfaces it may occur. if your model has collision between two objects and you are getting this error, try using *contact controls. Please describe model more.
