Hossein Mohammadi H
I am trying to do a 2D dynamic implicit simulation and I have defined density for all parts in my model, except one part which is discrete rigid and I defined a reference point on it and I gave it an inertia. My model works when I use Moderate dissipation or Quasi-static options in step, while when I change it to Transient fidelity it gives me the following error:
"Global mass matrix is singular. Please specify proper material densities, concentrated masses and rotary inertias, or nonstructural mass to fix the mass matrix. As a workaround, *dynamic, singular mass=warning can be used."
If the problem is mass or density, why does it work in moderate dissipation? Do you know how I can resolve this problem?
Thank you for your help in advance,
Hossein Mohammadi
Hossein Mohammadi
