Error on save after revise.
mag00
45
Hello again.
I've revised some items and after that I'm opening them in NX to work on them.
One of this items don't let me save it showing attached message.
Checking in TCe named references I noticed that it probably made something wrong when I revised it.
It is calling the 00 revision ugpart-atributes file in 01 revision.
Something I can do to correct it or I need to delete this revision and create it again?
Thanks.
*Tried to upload extra png images directly to the post, but it is not loading the image.
Gerson Fioravanti Junior
Mechanical Production Engineer
 http://files.engineering.com/getfile.aspx?folder=716bbbfa-28d7-493a-bc73-89385311db07&file=ERROR-NX9034_previous_version_not_loaded.png
The 00 revision was flagged and locked.
Can't get the check out. But why should I have the check out?
Other items that I revised works fine, without this issue.
Maybe its just a bug and I had no luck that it occurs with me?
I will kill the 01 revision and create a new one to see what happens.
