Error Isogen of Cadworx
Cronos_2P
18
Hi everyone,
I am trying to generate isometric plans in Cadworx Plant 2018, I already have my isos folder configured, but when I execute the IGO or IGB command, I get the following error: Error opening file for write (1) File: C:\WINDOWS\system32\isogen.log.
and I don't know how to solve it.
I hope you can help me.
In advance thank you very much for the help.
Thank you very much for your help Carlos, it is not clear to me how to solve the error, I cannot understand what option you mean by saying that it should not be blank.
I don't have Cadworx to check, I just found that someone posted how they had solved it..
From that response, it appears there is a menu "Option" "Start In" that must not be blank. They used "c:\cadworx 2018\". You would enter path where yours is installed.
If that doesn't do it, search and/or post question on forum
Thank you very much for the help CarlB, so I will
