mjpetrag
- Oct 16, 2007
- 224
I have a very low flow PD pump that puts an basic chemical into a product stream to raise pH. The flow of the chemical is typically 0.3 GPH and doesn't vary much. The PD pump flow is controlled by the stroke of the piston on a 1200 RPM motor. The flow is measured with a small coriolis meter. The chemical pipe is 1" diameter and the distance to the product stream is approximately 300' away. There is a 50' horizontal run before it 90's down into the product piping.
The product stream that the chemical is pumped into is 4" and the flow is approximately 10000 GPH. After the chemical ties into the product stream, it flows through a static mixer and then travels approximately 100' away to a product storage tank.
The results for pH are taken just before the combined stream enters the storage tank.
The problem we're having is that the pH results vary between 0.5 pH to 3 pH from sample to sample even though the flows have remained the same.
We sampled the tank and the pH is relatively constant at 2.5 pH across samples.
I'm wondering if we have a situation where we have a partially full pipe for the chemical injection and even though the chemical flow is reading fairly constant, the material could be building up and we get waves of the chemical in to the product stream causing the variation in pH.
Am I correct in my thinking?
-Mike
-Mike
