I can see where KiwiMace is coming from.
The process flow on the fermentation side of these plants can be extremely complicated. As you're dealing with biologicals, until you get to DD&E, you have to be prepared to do anything at any time with the live cultures to keep the bugs going. Heat them, cool them, feed them, stir them, burp them, move them forward in the process, return them to an earlier point in the process, read to them... they are delicate and FINICKY. On top of that, you throw in batch/continuous process parameters and your actual utility load needs in fermentation can end up being very hard to nail down.
Once you get to distillation, then the operation of the plant becomes more of a typical chemical plant running as a relatively unchanging continuous process, but before you get to that point, the flow of material and energy through fermentation can be a nightmare to untangle.
