Equivalent pressure for bolted joint
edemarcos
IT
Please, I need to know how to calculate the equivalent pressure acting on bolted joint due to an external bending moment and axial load.
Many thanks in advance.
Check out thread378-18541. Good luck...
You may want to revisit the thread mentioned above, as more infor has been added.
Hi , edemarcos:
I´m a spanish Mech. Eng. and I've been working during 10 years in design of heat exchangers and Pressure vessels. Your doubt is totally clearificated in a good book called
Pressure Vessel Design Manual of Robert Moss , in the applicable design chapter about the flanges.
You can obtain Equivalent pressure using the following equation:
Peq = 16*M/(pi()*G**3)+4*F/(pi()*G**2)+P
using M bending moment(in-lb) and F radial load (lb)
Calidad is absolutely right. BTW, ASME III NB has the same formula.
