bimr, I think you took me in a circle with your suggestion. Although, I'm not sure the original poster asked a question that could be answered with the information given.
Equivalent length allows you to calculate total headloss from approximations, as bimr meant to describe, not flow rate. The headloss and flowrate are then indirectly proportional (and dependent on one another).
In general, equivalent lengths allow you to lump minor losses all into a length term. That is, say you have a 1000 foot pipeline with various bends, valves, tees, etc. These appurtenances introduce losses that aren't easily characterized. So, various texts will suggest equivalent lengths for the various appurtenances based on their size and configuration. For example, an elbow might be assigned a value of 6 feet...again, the values are published in various texts. These values would be summed and that total additional length added to the real pipeline length. So, this theoretical "length" would then be used directly in the conventional equations for headloss. In doing so, you would also need to know at what flow rate you are evaluating the loss. In generating a system curve you would do this over your range of interested flows.
