Okay, this sounds like an off-the-wall question. I've seen similar topics discussed before but they haven't led me to any answers. My company is doing leak testing on jetboxes (not sure of the details on them so please don't ask). Normally a hydrostatic test is done at a certain pressure to find any leaks/defects in the component. Some of our customers want a nitrogen leak test done.
What I need to figure out is at what pressure the nitrogen should be applied to cause an equivalent amount of leakage as the water test. The theory behind this is that a gas (nitrogen) will leak more readily than water and can therefore be applied at a lower pressure to reveal the same defects. If anyone has any ideas, I welcome the help. Thanks!
