I understand the equivalent pressure method to be a conservative method for evaluating tendency of a pipe flange to leak, and particularly when using the temperature/pressure ratings lookup as the threshold.
That said, for a scenario in which I have a class 250 flanged valve mated with a class 300 pipe flange, is it appropriate to use the Class 250 pressure/temperature ratings using this method? This sets the allowable flange pressure much lower than class 300, despite being the same size.
