Equipment schedules
windseaker1
34
I am looking for a national Engineering or even a Cad standard for equipment schedules?
I have noticed that ASNI/ISA 5.1 is used for P&ID on drawings but there must be a print standard for equipment schedules naming convention. The correct standard names and acronyms list or data list is what I am after to convert to a CMMS system too.
Example:
Feed water pump FWP-1
or
Pump, Feed water FWP-1
Air Handling unit AHU-SF1 ---> AHU-1 supply fan
Thank you
What is so wrong with a check and balance system! Money vs Life
 https://files.engineering.com/getfile.aspx?folder=2f532441-4a99-4024-9431-c747984e6087&file=test5_(1).pdf
