gotothesky
Hello,all..
I am a engineer for boiler thermal design.
For Deaerator, I would like to design with PACKING Material....
(I mean packing tower such like stripping column...)
My proposal as above is reasonable. But, nobody considers PACKING column for a Deaerator....
Is there any person who can explain why Packing column is not applied for a Deaerator..
In addition, Deaerator is needed for boiler system to remove oxygen in water that is used for the system.
I don't know exactly.... but, Packing column has simple construction.. it means that Fabrication cost of a Deaerator can be reduced with Packing column construction.
In order to make a Deaerator be high efficient, Some tray should be installed in a Deaerator as internals.
The purpose of internals is to increase contact between water & steam.
The tray is made from steel.
Thank in advance for your kind answer.....
