Based on past experience, I'd say that less than 10A is probably not worth chasing down unless it is causing some specific problem. One source can be dual source lighting (normal and emergency into the same luminaire) with the two neutrals tied together.
I'd just continue to monitor the current and watch for sudden increases and try to figure out what causes them; otherwise leave it for those times that you don't have anything else to do.
