Equipment for performing weld overlay on nozzles smaller than 3 inches
FPPE
IT
Hi everyone,
Could you recommend a machine for performing internal weld overlay on nozzles with a diameter of 3 inches and below (e.g., a 2" LWN #300, which has an internal diameter of about 50 mm)?
We routinely perform weld overlay on heat exchangers, vessels, etc., but we do not have the appropriate equipment for small-diameter nozzles.
Thanks in advance for the answers!
Solution
Ive once seen a demo of Polysoude where they (for a customer in the EU, perhaps NL) had to internally clad some small dia large length (say 6 mtrs?) pipe. Dont know the exact dimensions, but you may give them a try.
Solution
XL83NL, thank you very much, I'll contact them right away!
If the overlay is stainless steel why not use a solid stainless steel nozzle?
r6155,
Thank you for your reply.
If the solution were that simple (and luckily it isn’t), the number of engineers in this field would drop dramatically.
r6155, some of our clients have experienced problems for integral nozzles (for example in SS) welded directly on a CS shell internally cladded in SS, so simply they do not permit and you have to clad also the nozzle. Unfortunately this is mandatory.
What's difficult?
Be practical.
Again @r6155, be productive and helpful when you comment rather than being dismissive.
Also, using solid SS alloys on CS+Clad vessels are prohibited by most Owners/Contractors due to thermal expansion difference which causes localized stresses. Those are only utilized on near ambient temperatures.
Trestala, exactly, thank you.
The use of corrosion resistant integral or weld metal overlay cladding or lining material of chromium‐alloy stainless steel with a chromium content of over 14% is not recommended for service metal temperatures above 800°F (425°C).
The thermal expansion stresses btw CS base metal shell & a solid SS nozzle vary greatly depending on the nozzle size. In the case of smaller nozzles (<3"), these stresses are typically acceptable (depending on operating temp) & solid SS nozzles can be a practical & cheaper solution, even if it's seen an unconventional.
The cladding requirement is often due to chloride stress corrosio cracking issues. In many other environments solid corrosion resisstant alloys may be used in clad vessels. In the past a number of vessel manufacturers created their own equipment to overlay pipe components 2" diameter. I also saw Polysoude demonstrate it"s AGTAW system on 2" diameter pipe sample.
Thank you all for the answers!
