Hi! Maybe this question is more appropriate for the "Engineering Codes, Standards & Certifications" section but I'm not sure which standard I need...and I thought the HVAC people might have the best knowledge of standards that apply to plenum space or suspended ceiling space. I am working on an OEM enclosure design that will be located above the suspended ceiling which will house a projector, some electronics, mirror, and a motor that will drop the mirror into a room to reflect an image onto a screen. The weight of the enclosure and equipment will then be suspended from the concrete ceiling using expansion bolts. This will be sold and installed in various buildings in the United States. Do you guys know what certification this will need in order to be installed in US buildings? New and existing construction. Would it be just a UL mark? NFPA testing? or some other governing body that a facilities engineer would ask for or require before installation? Thanks!
Aron
Aron
