I have an assembly which contains several different configurations of a part. I want to create an equation that will contain dimensions specific to a certain configuration. But doesn't look I can do that.
Let me clarify with a simple example: let's say the part is a cylindrical rod. This part has multiple configurations and the configurations differ in respect to the length of the rod. Now I insert several instances of this rod into an assembly. Some of the instances are different configurations (i.e. different lengths). Now I want to create an equation such that the equation will only affect a specific instance (configuration). But when I select that dimension (length in this case) to add to the equation, it looks like that the equation doesn't differentiate between the configurations and changes the length of all the instances (configurations).
Please suggest if there is a way to do this.
Thanks to all the readers.
