hello,
I have built an assembly of guarding using box section and inch mesh(horizontal & vertical bars).
I have created an equation in the assembly between the top length of SHS and horizontal bar of the inch mesh so when I change the length of the SHS the bar length changes accordingly.
The vertical bar of the inch mesh is always at a constant length so no changes need to be made. I have used the pattern feature to distance the bars accordingly. Is it possible to create an equation relative to the component pattern that would place so many vertical bars at 1” apart according to the length of SHS?
Picture below shows standard panel.
Picture below shows modified panel.
Thanks,
Callum
Thanks,
Callum
