FLCraneBuilder
Industrial
For setting Overhead crane columns, We prefer to Epoxy set anchors after the Slab (or footers) are cured
This is because cast in place anchors are rarely done correctly - crane system alignment is critical to function of crane.
A situation has arisen where the foundation installer cannot tell us where the rebar is, and the foundation engineer forbids us from drilling thru the rebar if we encounter it. (when we encounter it).
I'm sure in the past, we ended up drilling thru the rebar more often than I should admit... and its never been a problem (yet?)
I feel that if one drills thru (basically cuts) the bar, the combined presence of the steel anchor and the epoxy material "re-creates" the continuity of the bar.
I recognize the shear strength of the epoxy is less than the rebar steel, but the Epoxy is usually stronger than the anchors... so....
A few more details:
-- 7/8" dia steel threaded rods for anchors
-- B-7 Material (higher strength material)
-- 8" imbed
-- Anchor pull out is approx 5200# - (The columns see moment loads)
-- Rated capacity of anchor/epoxy combination is 9600#
-- Our guys are meticulous about clean holes, proper epoxy setting to achieve bond etc
-- First layer of rebar is 3" below top of footer, second layer 13" below top of footer
Any experiences or opinions on this would be appreciated
BTW - I did a thread search and did not find anything
A few more details:
-- 8" imbed
