VodovodnoOmrezje
thread164-349880
Hi to all!
I am new to EPANET. When I run "dynamic pattern" for 24 hours, it warns me:
WARNING: Negative pressure at 5:00:00 hrs.
WARNING: Pump open but exceeds maximum flow at 5:00 hrs.
On the one side of the system is a reservoir (water well; supposing that it has enough yield) and on the other side on higher level is a tank.
How can I solve my problem, should I increase the diameters of the pipes, or install more powerfull pump (greater flow).
Thank you for your help,
VO
Hi to all!
VO
