johnyt79
- Mar 4, 2010
- 4
I am currently modeling a watersystem with a pump with a continuous fresh source to a reservoir joined by a common main (i.e. no dedicated line to the reservoir). The system feeds a single family development.
I want to check the quality (age) of the water within the reservoir, theoreticaly the age of the water should taper off at around 4 days or so. However in the analysis, the age is proportional at 1:1 with the time lasped over the analysis (i.e. a 500 hours analysis spits out a water quality of 500 hours). This occures only at the reservoir.
At the demand nodes throughout the development, there are rediculous fluctuations. As when the pump is on, which means the line is being replaced with fresh water, the quality is very good (4 hours at most), and then when the pump flips off the system is fed by the reservoir which has a very poor quality as explained above.
Viewing the reservoir during the pump cycles, it shows both flow in and flow out, but quality never changes.
This should be purely an issue with the way i setup the EPANET analysis.
Can anyone help? more information required?
Thanks!
Thanks!
